Mariner 75 Which Stator. Please
axscuba
Hi<br />I have just replaced a faulty Stator on my Mariner 75 1993.<br />The original Stator had the serial number 398-9710-A28.<br />The replacement Stator(used) number. 398-8320-75-A4.<br />My question is whether I have replaced the faulty Stator with the correct part. I am not sure which one is 16amp or 9amp.<br /><br />I have run the engine and so far it is going ok.
Bob H.
Re: Mariner 75 Which Stator. Please
9 or 16 amp won't likely matter unless you're running a bunch of electronics plus trying to charge the battery. I had the same problem a while back - Mercury played with p/n's and some color codes and I wasn't sure what stator I got. A load test told me I got the 16amp that I wanted.
Laotzu
I have a parts list I got from a merc tech when I bought a part. It has all the 8320-75-A's except A4. Thats way it always seems to be! Anyway all the other 8320-75-A's are red stator conversions from 9 to 16 amp. So, chances are if you have a red stator, it's most likely 16 amp.<br /><br />Jerry
