  #1
Old March 25th, 2006, 12:35 AM
Daddy Daycare Daddy Daycare is offline
Default 30hp Mariner warning alarm won't stop.
Have a 96 Mariner 30hp with oil injection. Were out last weekend when a sudden high pitched alarm went off. It was a continuous beep which after a while increased in pitch. Checked the oil injector reservoir and it was very lowtyhough the gauge showed 3/4 full. We cruised slowly back to the boat ramp which took about 10 minutes. The alarm started at high revs but continued even when idling out of gear. Water flow from the pump was good and the water was cool. We filled up the oil reservoir but the alarm is still sounding. Exhaust gases are blue and the performance of the motor does not appear to have changed. The alarm still goes off everytime I start the outboard. Any ideas on the the cause and what I might be able to do to fix it?
  #2
Old March 25th, 2006, 02:54 AM
Moody Blue Moody Blue is offline
Default Re: 30hp Mariner warning alarm won't stop.
The alarms are there to tell you something is wrong. Continuing to run the motor in this situation is asking for trouble. What you are hearing is an overheat alarm, and if its valid, you run a good chance of seizing the motor. It may also be a short somewhere in the wiring that is causing the alarm but you need to find the true cause before running the motor anymore. The low oil alarm is an intermittant beep-beep-beep-beep. Doeas the alarm sound even if the motor is not running but the key is in the ON position?
  #3
Old March 25th, 2006, 02:56 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Welocme to iboats. There could be a short in the overheat wiring, the warining module could be bad, or the alarm itself could be bad.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #4
Old March 25th, 2006, 04:22 AM
Texasmark's Avatar
Texasmark Texasmark is offline
The system is easy to check. Pull the tan (on my Merc)lead off the head temp sensor, or disconnect the tan lead from the wiring harness going to the lead coming out of the temp sensor (sensor is visable from the rear of the engine, coming out of the head's water jacket near the spark plugs) and see if the alarm stops (with with ignition key on).If it stays on you have wiring problems. If it goes off and the engine is cold it has internally shorted. Alarm position for this switch is a direct short to the engine's block.While you are in there you might check your thermostat or just replace it. Mine is stamped with 120 degrees on it and if you put it on a pot of water and heat to a boil, you will (should) see the end (oopposite the pellet) extend about 1/4 inch from the body when fully opened. It should come off it's seat at around 120 and be fully opened within 10 or so degrees.A candy or baking thermometer in the water helps to know the exact temp. Turn the fire down low so that the sensor in the thermostat has time to respond to the water temp. It is deliberately made large (the pellet) to measure average temperature.If the water boils and the end hasn't extended get a new one......iboats has the whole kit (gaskets included) for about $13 bucks. Just ordered one and works just fine. Checked it in a pot of water before installation.Mark
  #5
Old March 25th, 2006, 01:01 PM
Thanks for your responses. In answer to RODCs question yes it does sound when the key is in the on position.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 30hp Continuous Alarm TSoko Mercury & Mariner Outboards 10 October 1st, 2006 11:57 PM
Warning alarm won't stop buzzing. andy6374 Mercury & Mariner Outboards 4 September 5th, 2005 07:20 PM
intermittent warning alarm on 150HP Mariner Outboard jkruman Mercury & Mariner Outboards 3 July 23rd, 2004 07:36 PM
testing overheat alarm on Mariner 30hp Craig Williams Mercury & Mariner Outboards 11 August 24th, 2003 08:57 AM
Warning alarm 1994 Mariner OB Sam Cloud Mercury & Mariner Outboards 0 July 1st, 2002 08:56 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
