1999 125hp Mercury - Low speed stall
Karls
Just trying to figure out a good place to start on this one. I have a 1999 125hp Mercury has one annoying problem. It will stall when cruising for a while (5 minutes) at idle / low speeds. It will not restart after it dies for at least a 5 to 10 minute resting period, after which it will usually fire up as if nothing happened. The engine runs strong at higher speeds and has a nice idle. There are no other noticeable problems with this motor. <br /><br />Also I see that impeller replacement is a recommended as a preventative measure. Is this necessary in freshwater, if so how often?<br /><br />I have minimal marine engine experience, but I have pretty strong automotive experience and electrical background. I have not had the opportunity to check for spark when the motor is dead in the water, but that is the direction I am headed in. All comments are welcome!
Karls
Re: 1999 125hp Mercury - Low speed stall
I thought this might also be useful information.<br />Serial# 0G882661<br />ELPTO<br />1999 125HP Mercury<br /><br />Anybody have any theories on why this would stall? Trigger? Stator? CDI Pack? Bad Karma?
OperativeK
Check your compression lately? Mine went out this weekend zero compression on #2.
Karls
I just got around to checking compression. The testor measured 95 on all 4 cylinders. I also noticed when performing the compression test the starter drive gear bounces up and down repeatedly when the starter is cranking. Sometimes it will only turn the flywheel for a second and disengages. Any ideas why this would not stay engaged?
