NYLaguna2100
- May 21, 2005
- 14
Hello,<br /><br />I've checked the send wire and it is getting current right up to the tach and I've installed a brand new tach. What is causing this not to work. Does this motor have a voltage regulator. Someone told me to check the rectifier and voltage regulator. The volt gauge is showing 12 or so volts and rises when the throtle is raised. How should I go about trouble shooting this. Any thoughts, much appreciated. Chris
