Time's an issue. Try your public library. Many have manuals. That's a very common Mercury configuration. Any manual that includes Merc will cover it.
It's fairly easy to remove. The zinc trim tab above the prop has to come off to get to one of the fasteners. Otherwise you can see all of them. You won't need any special tools except maybe a big allen wrench for the bolt that holds the trim tab. You'll need an impeller and you should replace the base plate gaskets. If any of the plastic parts are melted, do a complete pump.
Before putting the housing back on the pump, lubricate the impeller and housing with any thick soap (shampoo, dish soap, laundry detergent, etc). While turning the driveshaft clockwise, push the pump housing over the impeller. Getting the gearcase back on is frustrating to those that don't do a lot of them. That's where the manual will help.
Good luck and feel free to ask any questions.
