  #1
Old February 22nd, 2006, 02:54 PM
bnbad11 bnbad11 is offline
Default 1979 70 hp mercury stalls when putting in forward or reverse from neutral
My motor stalls when i go from neutral to forward or reverse. starts right back up but does it repeatetly. it has run fine until now. won't idle at low rpm idles great at higher rpm .it goes in forward when on trailer hooked up to the hose! but not in water under load. I recently replaced switch box,stator, fuel diaphram,all fuel lines. also when trimmed all the way dowm boat seems to slow down alot, even rpms go down almost like i throttled down runs faster and sounds better with tilt up alot, but when i turn it winds up and i have to trim down.????? HELP!!!
  #2
Old February 22nd, 2006, 03:24 PM
timmathis's Avatar
timmathis timmathis is offline
Default Re: 1979 70 hp mercury stalls when putting in forward or reverse from neutral
It sounds like it could the carb float adjustment. I'm Not sure on that year model though. Maybe a pro on that one will help.Good Luck, Tim
  #3
Old February 22nd, 2006, 03:33 PM
Thanks. I am trying to figure it out with out taking her to the shop but it looks like i might have to.
  #4
Old February 23rd, 2006, 05:23 AM
Texasmark's Avatar
Texasmark Texasmark is offline
You are suffering from fuel starvation. Everything you said points to that. Cause? just have to chase her down.On the trimming down part, you are "plowing" your boat which is increasing the load on the engine, which takes more fuel to maintain the status quo and you aren't getting it so she boggs down.Sounds like low speed jets are clogged (or adjusted too lean if adjustable) if the float is not part of the problem. Might read up on the "decarb" thing. May have your answer there.Mark
  #5
Old February 23rd, 2006, 06:24 PM
Boatwizard Boatwizard is offline
Have you checked the compression, spark and fuel? Have you pumped the ball and see if it hold tight or leaks down? Do the basic checks first, never overlook the obvious.
  #6
Old February 24th, 2006, 06:51 AM
have not checked compression. spark is good. i just replaced all fuel line from the tank to the motor. ball stays hard now. did not before. still stalls when shifting into forward or reverse. ???? driving me nuts!!!
  #7
Old February 24th, 2006, 07:09 AM
Silvertip Silvertip is offline
The engine will idle differently running on muffs than in the water due to back pressure when in the water. You need to set idle mixture and idle speed in the water. sounds like all that's necessary is better adjustments. Its idling too slow in the water. Set mixture first, then idle speed.
  #8
Old February 24th, 2006, 10:21 AM
i was just told from the marine shop that there is a hole in the exhaust plate? and water is actually comming in the motor??? never heard of an exhaust plate. Does that sound right?
  #9
Old February 24th, 2006, 11:09 AM
Texasmark's Avatar
Over my head. I know we have exhausts, tuned exhausts, with tubes and sound revibrators and all that tech stuff, with sound absorbing water surrounding it and all, but an exhaust plate?Now I do understand that in salt water, you can corrode thru the cylinder wall and thus get water in the combustion chamber. BTDTMark
  #10
Old February 24th, 2006, 11:15 AM
That's an exhaust cover on the side of the engine. If you are getting water into the cylinders it certainly will idle and run poorly and it needs to be fixed. Run the engine, pull the plugs and check to see if one or more are pure white while others are tan colored which is an indication of water ingestion. If you intend to work on this problem yourself -- do yourself a big favor and buy a service manual specific to your engine.
  #11
Old February 24th, 2006, 11:58 AM
I just got back from the shop. he showed me the hole it's about an inch long on the side of the plate,corroded.(cover) (don't remember if it was in the inner or the out plate) with this plate removed i could see the cylinders from the side. he told me that the water under pressure was leaking into the cylinders and killing the spark. Hopefully around a $200 job he said. let's see if that works!! thanks for all the responses.
  #12
Old February 24th, 2006, 02:13 PM
Yes -- water getting into the engine will definitely put out the fire. Good luck on the repair.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Wont go into neutral or reverse, stuck in forward shute421 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 July 11th, 2006 04:00 PM
Engine Stalls when shifting from Forward to Neutral or Reverse to Neutral jules03 Johnson & Evinrude Outboards 6 May 10th, 2006 07:21 AM
Noise when shifting from Neutral to Forward/Reverse Technician Force & Chrysler Outboards 4 June 11th, 2005 05:12 PM
1993 Mercury 8, Neutral Low speed Idle quits, Forward & Reverse work just fi we2sail Mercury & Mariner Outboards 2 July 7th, 2004 04:39 PM
1979 100 HP Johnson skips from forward to neutral aJohn79 Johnson & Evinrude Outboards 2 July 17th, 2002 12:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
