I have a 1990 40 HP Merc that was sitting for about 6 years, I drained the fluids and replaced the plugs and batery and it started up. No water came out the discharge point on the side of the motor. Some of the line was plugged. I dropped the bottom of the shaft and was abble to get water thru the pump. Then ran water thru the copper pipe leading up to the engine. Water then came out of the disharage point, but i also noticed water comming out of the bottom of the engine where the water intake enters the block. I cant see the exact spot it is exiting from, but that seals looks good all the way around where I can see it. Is that normal, does not seem right to me?
