cheburashka
- May 28, 2005
- 715
I just purchased a boat that came with a '58 Mercury Mark 30E. I'm trying to clean out the old grease and replace the water pump impeller. I've checked the manual, which says that to remove the lower unit, you need to pull one central 9/16 nut from the bottom, and the two smaller side nuts from the top. I've done this, and there's no bolt in the exhaust port or anywhere else I can find, but the lower unit won't separate from the engine. The prop is still attached, as is the power unit. Is there something else I need to remove?<br /><br />Thanks.
