Re: Busted Speddometer and Tachometer
There should be a piece of tubing running up inside the lower end, and heading towards the dash console. Water enters the little hole in the lower end, and creates pressure in the tube (pitot tube). Thats pressure is what makes the speedo needle move. Somewhere along there it should have a connector that can be pulled apart (near the motor). Take the connection apart, and blow into the part that is attached to the motor, while trying to remove the debris.<br /><br />Also, you should be able to blow gently into the end attached to the speedo and see the needle move. The tubing deteriorates over time, and may develop leaks or be pinched in such a way as to render them ineffective. Pitot tube is cheap, and quite easy to replace completely.<br /><br />Get the hole, and tubing cleaned out and go from there.<br /><br />Note: This is assuming your speedo is connected to the motor. You may find that an external speedo pickup is connected to the transom of the boat instead. Is is normally mounted at the rear bottom edge of the boat on the right side. Looks like a hinged lever assembly, with a pitot tube connected to it. <br /><br />Both methods are popular, and you could have either one.
