  #1
Old December 23rd, 2005, 07:13 AM
cpgdude cpgdude is offline
Default 20HP Mercury O/B - "Sticky" Shifting Problem
This is a 20HP Mercury, Electric Start, Long Shaft Outboard, manufactured in 1980, S/N: 5607390After shifting the motor into reverse, it doesn't want to shift easily back to neutral. When it does disengage, it doesn't want to shift into forward without some effort. I recently changed the gear lube in the lower unit. I bought this motor a while back and have only used it a couple of times, so I don't have much history with it. This problem seems intermittent - other times it seems to work OK. Any suggestions or information would be greatly appreciated! Thanks in advance!
  #2
Old December 23rd, 2005, 12:09 PM
Chris Graham Chris Graham is offline
Default Re: 20HP Mercury O/B - "Sticky" Shifting Problem
Hi RayI Have had this problem with my 50hp Merc and found it to be the holding catches were not engaging. This stops the motor from engaing into gear while it is tilted and alos lifting while it is in gear. Have a look at this when it is locked down. Worth a look.
  #3
Old December 23rd, 2005, 02:52 PM
DHPMARINE DHPMARINE is offline
I don't think this is your answer,but most motors are hard to shift unless running,or at least turning the propshaft.DHP
  #4
Old December 24th, 2005, 06:19 AM
Motor Boater Bill Motor Boater Bill is offline
Have you lubricated the linkages? Also, is it tiller or remote? If remote, could be all in the cables and control.
  #5
Old January 5th, 2006, 06:20 PM
andrewkafp andrewkafp is offline
RayIf your motor is manual tilt (No hydraulic t/t), there are 2 hooks that lock onto a bar at the transom, when in reverse and neutral. If these are not kept clean and lubricated, they jam on the bar and when you disegage reverse, they remain locked, thus stuck in reverse. If this is the case,move the gear stick to neutral and lightly tap the hooks with a hammer and just oil them and run some penetrating oil down the shift shaft to free up the reverse locking cam.
  #6
Old February 1st, 2009, 12:19 AM
fltbtmred fltbtmred is offline
i swear it sounds like you have my motor that is exactly what mine does .it is hard to get into nuetral and reverse.my motor is a 20hp electric start and i also believe it is a long shaft motor
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 150 problem "beeping" cashanab Mercury & Mariner Outboards 11 July 20th, 2004 06:41 AM
72 mercury 115 outboard " idle problem" penguin Mercury & Mariner Outboards 1 November 3rd, 2003 01:12 AM
"73" 50hp johnson shifting problem? anthony_sav Johnson & Evinrude Outboards 3 May 9th, 2003 10:08 AM
Mercury "200" 20hp Cooling bjarnold Mercury & Mariner Outboards 4 March 12th, 2003 07:07 PM
20HP Mercury "Surging" Jango Mercury & Mariner Outboards 5 June 11th, 2002 11:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
