  #1
Old December 7th, 2005, 07:19 AM
calm like a bomb calm like a bomb is offline
Default 1997 Mercury XR6 150hp tell-tale stream is hot !!
Water pump takes about one minute to force water out of the telltale stream and when it does it is very hot. Is this a stuck thermostat or poppet valve?The engine supposedly had new thermostats installed about one month ago.Any ideas please reply..THANKS!
  #2
Old December 7th, 2005, 08:09 AM
Kenny Bush Kenny Bush is offline
Default Re: 1997 Mercury XR6 150hp tell-tale stream is hot !!
It takes at least a minute to come out of the tell'tale. It will be hot, you should only be able to hold your hand in it for a couple of seconds. Sounds like your is doing what it should.
  #3
Old December 7th, 2005, 08:26 AM
The shop says it should cool down soon after though and it does not. I own four boats now and about a dozen over time and this one is the only outboard I have ever seen that the tell-tell stream of water is scalding hot and stays that way. It is not circirculating cold water through the engine. Anybody??
  #4
Old December 7th, 2005, 10:19 AM
LubeDude's Avatar
LubeDude LubeDude is offline
Without a temperature guage, we have no idea whats going on. Sure sounds like its doing what its suppose to though. Running on the muffs isnt like running it on the water. Of course there is cold water circulating, you are putting cold water in and hot water is coming out.
  #5
Old December 7th, 2005, 10:33 AM
parkert50 parkert50 is offline
Try to take the motor cover off and look at the hose that the water comes out of. Follow that hose up and it should connect to the top of the cyl. head. In the top of the cyl. head on both sides are the thermostats. Hot water is always either going passed the thermostats, or when the thermostats open. Do you notice that the water comes out stronger at times? This is when the thermostats are open. I will tell you that in most fresh water cases the water pump itself is to blame for overheat problems.
  #6
Old December 7th, 2005, 12:19 PM
Finally talked to a local Merc tech and he said all seems normal...he said the thermostats open @ 143 degrees and this engine design exits hot water under normal cirumstances. New problem is the overheat alarm horn that should sound does not function when the key is first turned to the On position. I have to cure that and install a Teleflex water temp gauge and then I'll quit worrying about that. Thanks to all that replied. <*//><
  #7
Old December 7th, 2005, 04:17 PM
andy6374 andy6374 is offline
If your intentions are to make sure your engine is cooling properly, I would pass on the temp gauge and opt for a water pressure gauge (both would be best). The gauge will let you know when thermostats open/shut and when the popppet valve opens and closes. You'll soon associate a particular water pressure with a certain RPM range and be able to detect right away if something is shot in the cooling system-andy
  #8
Old December 7th, 2005, 07:43 PM
andy6374, It has a good water pressure gauge that is working.I finally talked to an owner of another V-6 Merc and he confirmed what the Merc tech told me about the 143 degree temp.The tell-tale stream is gonna be hot and stay hot and his engine takes about one minute to start the stream also,after the thermostats open @ 143*. He has 500 hours on it and loves it.I will install a temp gauge and get the alarm in working order and should be good to go..I hope.
  #9
Old December 8th, 2005, 03:51 AM
Yep, merc's have a hot tell-tale. Unlike other outboards whose tell-tales exit before cooling the block, on merc's the water has been circulated through the block before it exits. My V6 Black Max does the same-andy
  #10
Old December 8th, 2005, 05:10 AM
Ditto on the water pressure guage... Once you see what the pressures are at different RPM's, you will be much more in tune with your cooling system.
  #11
Old December 10th, 2005, 03:36 PM
KCLOST KCLOST is offline
One minute??????That don't sound right... You should see at least a little water after about 15 seconds...IMO..And if you are running off of the muffs or even in the lake it will not be scalding hot at all just after it starts leaving the tell tail...Somethins is wrong.... Check the water pump.. And or the poppet...
  #12
Old December 10th, 2005, 03:37 PM
There is still a bypass around the t-stats that will allow some water to exit the tell-tail even if the water is not up to 143F...
  #13
Old December 10th, 2005, 03:38 PM
Another note.. What are your water pressure readings at idle?
  #14
Old December 10th, 2005, 05:40 PM
KCLOST, This is a 1997 XR-6 engine.150 hpEveryone I have heard from including Mercury mechanics and people who own this year engine says this is normal for this year model. I notice you list yours as a 1986 model.They may have changed a great deal since then,mine seems to be OK but it will take some getting used to waiting on the tell-tale stream to appear.Makes me a little nervous for now but I'll keep checking the gauges!!
  #15
Old December 11th, 2005, 02:43 PM
gss036 gss036 is offline
Calm, take about 25 minutes and change your thermostats. They are $10 each and if you have done them in a while, it is time. Then, check the poppet valve. Maybe try running water backwards through your pee-hole hose and see if it comes out the exhaust, it should.
  #16
Old December 12th, 2005, 05:54 AM
Guys...I have seen maybe one thermostat fail in 1000... That black anchor seems very normal...
  #17
Old December 12th, 2005, 09:06 AM
BushCat, I don't think that it is an issue on failure. I changed out mine this past year and am now trying to do my own mainence for the simple reason that the mechanic that I was paying to change the head gasket eyery 3 years didn't bother looking at the thermostats and they were the orginal from 1989 and were about 90% closed from salt build up. The more technical things I will still go back to him because he does know his stuff when it comes to Mercury engines. I asked him about it and his reply was simply that I did not ask him to check them??? Can you believe it??My pee stream is hot, but doesn't sound like it nearly as hot as described here. Use a cup and a candy thermometer and see hot hot it is running.
  #18
Old December 12th, 2005, 09:15 AM
gss036-Unfortunately this is common and lots of mechs in my area too go by the saying, "if it ain't broke don't fix it". Those guys are diluted and probably don't know of an engine works or the first thing when it comes to regular maintenance and would rather just keep replacing the defective part (the result) than just figure out what caused the failure (the cause).Fortunately, I have found a really good wrench. And I refer everyone I know to him. He is also the first to tell you, "you can do it yourself". He has even walked me through some stuff over the phone.Anyone from RI or near, I will pass him along.
  #19
Old December 12th, 2005, 09:22 AM
Quote:
Originally posted by gss036: Calm, take about 25 minutes and change your thermostats. They are $10 each and if you have done them in a while, it is time. Then, check the poppet valve. Maybe try running water backwards through your pee-hole hose and see if it comes out the exhaust, it should.
The thermostats are already brand new at this time.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1991 150 XR4 Tell-Tale Stream 27739 Mercury & Mariner Outboards 2 January 30th, 2007 06:38 PM
No tell tale stream tikka Mercury & Mariner Outboards 5 March 23rd, 2005 01:34 PM
Weakish tell-tale stream. help? davejohnson Mercury & Mariner Outboards 9 September 16th, 2004 07:07 AM
tell tale stream blown67 Mercury & Mariner Outboards 6 July 9th, 2004 05:54 PM
water tell tale stream Darian F. Johnson & Evinrude Outboards 2 April 4th, 2004 06:54 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
