1984 115hp Inline 6 Carbs
TroubledOne
I have a 1984 6 Cyl 115 HP was wondering how much power increase can I get by switching carbs. Can I improve power to 135HP? Is the differences just carburetion? Need More Power!!!! Anyone?
emckelvy
Re: 1984 115hp Inline 6 Carbs
You're not going to get much more out of that motor. It takes more than carbs to effect any significant HP increase, and typically all you'll get is a peaky motor which performs poorly at anything but full tilt.<br /><br />If you need more punch you're likely going to have to go for a V6. The inline is a great motor but you can only do so much with 99 C.I.<br /><br />BTW your motor is rated at the prop and so is at least equivalent to an older 135 HP.<br /><br />HTH..............ed
Clams Canino
Agreed........ the '84 115 is pretty much all it can be. Make sure it's tuned and propped correctly. It outta push an 18' runnabout over 40mph easily.<br /><br />-W
TroubledOne
Thanks for the info Guys. I have a 1984 17 ft Astroglass Fish/Ski. At WOT it runs 5300-5400 RPM and 53 MPH with a 20 Pitch Stainless. Yes that is plenty fast but it's not only top speed I'm looking for, I would like to get a much better holeshot. I have a 17 Pitch Alum prop, However it peaks much to quick goes to nearly 6000 RPM at approx 43 MPH.
