You're probably feeling tension from the impeller blades trying to go backwards.
Not recommended to rotate the flywheel other than in the normal direction of rotation of the motor (clockwise), as you're going to bust impeller blades if you continue to do so.
Impeller blades take a 'set' after running for so long and do not take kindly to being reversed!
Seeing as how you've not run it and it's probably not known the last time the impeller was replaced, I'd recommend doing that before you even attempt to run it. If you break an impeller blade, it's possible for the broken chunks to be forced up the water tube, causing even more grief.
You can get Sierra replacement parts from a number of places such as NAPA or
www.boatfix.com or for factory parts, go to the Merc official site,
www.mercurypartsexpress.com.
HTH.......ed
