I aquired this motor after it sat for 3 years. Changed the spark plugs and proceeded to try to start it. Spins, but won't "catch" and fire. Spark is present on atleast the top cylinder, when the primer bulb is pressed too hard, you can get a squirt of gas to come out of an opening at the top left of the carb (if facing head on). Figured I would see what ya'll could help with before I tear into it too far.<br /><br />Edit : 1998 Mercury 40 2 cycle (rebadged tracker)
