  #1
Old November 1st, 2005, 02:45 PM
Michael Singletary Michael Singletary is offline
Default 1996 25hp Mariner- Starts at Wide Open Throttle
I recently replace my 1985 25hp remote Mariner with a 1996 25hp remote Mariner. I hooked everything up and attempted to start it. When it started up it was in wide open throttle. I quickly cut the engine and attempted is several other times. I thought that I may have accidently reversed the linkage so I switched them. It then was only in gear in the neutral position and in neutral when you shifted it into forward or rerverse. Do I need to adjust the linkage? If so, how? Please help!
  #2
Old November 1st, 2005, 03:41 PM
DHPMARINE DHPMARINE is offline
Default Re: 1996 25hp Mariner- Starts at Wide Open Throttle
.With any remote I've seen the shift cable moves first,then the throttle cable.You have to decide from there.Does the throttle need to pull forward,or push backward to speed up.I think you have the wrong control box .DHP
  #3
Old November 1st, 2005, 04:17 PM
The throttle must pull forward to speed up. It is already pushed all the way up just by hooking up the linkage though. That is why is was reving all the way up when I started the motor. I unhooded the linkage totally and it idled fine though. AH! I see. The control box I have is set up to push to speed up and the motor I have needs it to pull to speed up. Does that sound right?
  #4
Old November 3rd, 2005, 03:26 PM
That is as right as you can be without me being there,myself.The older Mariners were pretty much Japanese,and required special controls.Your newer Mariner has been Mercanized,and is Merc compatable.DHP
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Wide Open Throttle How much use Straightup Boat Topics and Questions (not engine topics) 4 April 14th, 2005 01:01 PM
wide open throttle rjsilver Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 January 30th, 2005 07:59 PM
wide open throttle?? wally jr Boat Topics and Questions (not engine topics) 4 July 18th, 2004 07:41 PM
Wide Open Throttle alexc Non-Repair Outboard Discussions 11 August 20th, 2003 11:42 PM
9.9 1996 Johnson throttle stuck wide open Uncle Squishy Johnson & Evinrude Outboards 0 June 22nd, 2003 12:26 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
