I have a Mercury model 200 that will not start. I had the bowl on the carbeurator fixed last year because it had a leak, the choke is working fine, and it has brand new plugs, but it will still not start. About every 20 pulls on the cable it will backfire once, but nothing happens. <br /> I cleaned up the wire posts on the spark plug solenoids (coming from the electronic ignition) because they were really corroded. I'm assuming these are solenoids? They are orange and the spark plug wires plug into them. <br /><br />I've checked my kill switch to make sure it wasn't keeping the engine from starting. There are 2 wires from the ignition going up to the magneto, and 4 wires coming from the ignition going over to the spark plug solenoids....what is the safest way to check and make sure I'm getting a good spark? Is there a way to make sure the electronic ignition is working? or does anyone have an idea why this motor is not starting? I've also tried starting fluid to no avail.<br /><br />I should also mention that my fuel primer bulb does get hard, but if I pump too much on it I get gas coming out of a small slotted hole to the upper right of the carbuerator intake. I'm guessing this is an overflow port (I hope)? <br /><br />Thanks in advance for any help
