dajohnson53
- Apr 28, 2004
- 1,627
In my quest to smooth out the idle on my '74 Merc 110 (9.8) I discovered last night that the bottom cylinder is not firing properly. <br /><br />Last fall, it idled rough, but functional, and ran at high speed better. At trolling speed, it was a little rough, but worked fine for several long days of trolling.<br /><br />When I first got it I did the spray type decarb. treatment as described in the FAQ and instructions on the can of Seafoam Deep Creep.<br /><br />I checked the compression last fall as well as yesterday. Both times, both cylinders were approximately 125 lbs, within two pounds of each other.<br /><br />To smooth out the idle, I disassembled, soaked and blew out the carb this spring and actually thought (still think) that it is a little smoother idling afterwards. I can idle down a little slower without it killing. Running in barrel, it actually starts fine (just a couple of pulls choked, a couple unchoked and it fires right up) It still idles rough, but functionally OK both in neutral and in gear and still seems to smooth out quite a bit when I give it some gas. I can't run it WOT in the barrel, but certainly well above a fast trolling speed. I'm guessing about 50%<br /><br />Really the thing doesn't run horribly at idle and fast idle and I was really planning on just using it as-is.<br /><br />But, after running at a fairly fast speed in the tank for about 35 minutes, just as a matter of curiosity, having never done it before, I pulled the spark plug wire on the bottom cylinder - and it made no difference! Replaced it and then pulled the top cylinder and it stopped dead. Also, not knowing any better, I pulled these wires from the plugs with my bare hands. The bottom did nothing. The top wire shocked me when I pulled it off. <br /><br />Pulled plugs - both were brand new and still looked it. They are surface gap plugs. Can't remember the number, but they are the spec. from the owner's manual and the shop manual.<br /><br />The bottom one perfectly clean and really didn't look like it had a lot of fuel on it. The top one pretty much the same thing with a little sign of combustion (tiny bit of dark, oily residue)<br />Pulled plug wires. They look original, but no visible cracks. Terminals have no obvious corrosion.<br /><br />Next step is I have bought an adjustable spark tester and test tonight.<br /><br />Questions:<br /><br />What gap should I set on the spark tester?<br /><br />Is there anything else that would cause one cylinder to not fire? I know that if the spark strength is bad, I'll need to do some more troubleshooting and will seek guidance at that point. This is a single carb engine. I have no idea what the ignition components are having never dealt with any of this stuff before -but I do have a Merc. OEM shop manual and know how to use a multimeter.<br /><br />Should I replace the plug wires on general principle? If so, do I need to get Merc OEM wires - or are they generic?<br /><br />Thanks for any advice you can give. I'll report back on the spark test, but am trying to look a couple of steps ahead if possible.
