Thomas Perkins
- May 3, 2005
- 2
I have a 1985 175 horse 6 cylinder Mariner motor. My oil injection warning went off {fast intermittant} and I discovered a busted fuel line inside the motor. I replaced the fuel line, but alarm continues. The sensor in the internal resevoir checked out fine, as did the sensor for the oil pump, so I proceeded to check and see if I was running on all six cylinders. The three plugs on the starboard side are firing great, but the three on the port side won't fire. Plugs are brand new. There are three power packs, each controlling one plug on the port side and one on the starboard. Is it the ignition switch causing me this headache? Any other ideas? Thanks.
