I have a 60 hp Mariner OG381643 on a pontoon.Was running at 5000 rpm this weekend and it shut down to 3000.Compression is 110 in all cylinders.I am getting spark in all 3.I took the cover off carbs and when I rev it up a little it looks like it is blowing gas out of the bottom carb.it also has gas running out of the copper looking tube in that carb.Would that be a reed or what? Thanks
Could, but spitting gas is typically associated with a bad reed(s). Might be a combination of both a float/needle problem and a reed problem.If it were me, I'd remove & inspect the carbs and at the same time take a close look at the reeds through the intake opening (if you can see them) while the carbs are off.
Its hard to get a good look at the reeds through the intake mainfold. Basically your reeds are one way, meaning allows fuel and in but not out. If your reeds are worn fuel can get blown back out, through you carb troats and this is what you may be seeing. If its only a little gas I would imagine its a stuck inlet needle or that the float needs adjustment.
Hello!I know this was an older topic but I had the exact samething happen to me this weekend. I got it up to 5000 RPM 37mph and it bogged down to 3000 rmp and then ran at 3000rpm for like 3-5 sec and then kicked back in up going up to 5000rpm, it continued to do this for 15 min or so then started running great. I ran it wide open 5000rpm 37mph for about 5 miles no bogging at all. I did have the boat sitting for 2 1/2 months cranking only every other week but not running it wide open or in the water. I am wondering could my gas have just gone stale or gotten al ittle water in it and running it cleaned it out? I am going to remove the old gas and put new and replace the filter, would this clear the problem from the explained above issue?ThanksDwayen
