  #1
Old October 11th, 2005, 02:27 PM
jornelas jornelas is offline
Default STARTING PROBLEM 115 MARINER MOTOR
IM HAVING PROBLEMS STARTING MY OUTBOARD 115 HP MARINER ( 1987 ) MOTOR ( INVADER BOAT 18'), I HAVE TO REMOVE A SPURKPLUG SPRAIT WITH ETHER AND WILL RUN, THIS HAPPENS WEEN IS COLD... I CHANGE FOR A NEW ELECTRICAL HARNESS.. AND THE SAME PROBLEM CONTINUES....LAS WEEK GONE FISHING AND NOTICE MOTOR MAKING A LOT OF VAPOR WHAT CAN BE WRONG.. I USED 50:1 RATIO ON FUEL THATS CORRECT .. PLEASE HELP ...THE FUMES, WE NOT FROM THE OIL WERE CAMING OUT FROM THE HOLE WERE THE WATER ARE SUPPOS TO COME OUT..
  #2
Old October 11th, 2005, 03:37 PM
Vlad D Impeller's Avatar
Vlad D Impeller Vlad D Impeller is offline
Default Re: STARTING PROBLEM 115 MARINER MOTOR
Do not try to start that motor until you have had the carbs cleaned and the waterpump rebuilt.Get the compression checked, and do not spray ether into the engine.I hope that you have'nt done any damage to your motor.
__________________
'The past is history, the future is a mystery,
and now is a gift. That's why it's called the present'
  #3
Old October 12th, 2005, 10:38 AM
thank for the information will buy rebuilt kit for pump .. motor has no damage but carbs were clean and the problem continues having problem to start motor.. as soon its starts it will not hat a problem.. we push the gas manualy and will not star ween is cold.. do you think the supply of gas is not the appropited one at the moment we start the motor..
  #4
Old October 12th, 2005, 10:47 AM
this is the numbers on my 115 hp mariner 1987 outboard motor # 5180778 and 54935. wath type of water pump kit i have to buy .ween i bought the electric harnes the # 414-2770 this is the number they gayme..
  #5
Old October 12th, 2005, 08:44 PM
emckelvy emckelvy is offline
Make sure you pump up the priming bulb in the fuel line VERY hard before starting.When starting make sure your fast idle lever is giving it enough throttle to start.Make sure you are pushing in the key to choke the motor. The choke on this motor only works when the ignition is 'ON' and the key pushed in.If your motor has choke shutters on the front of the carbs, make sure they are moving when the choke is pushed. Make sure they shut all the way and seal against the carbs.If you have a primer valve instead of choke shutters, you'll see a brass-colored valve on the left side of the motor, with fuel lines hooked to it. There is a small knurled knob on top of the primer. If you open this up, it'll send fuel to the carbs when the primer bulb is pumped or when the engine is being cranked. With this 'knob' in the shut position, the primer valve operates electrically with the ignition key pushed in.If the primer is not letting gas go thru, your motor would be very hard to start. You can check this valve to see if gas is getting thru it.For your water pump kit, I'm assuming this is a 6-cylinder Inline motor and you'd want a Sierra 18-3217 impeller repair kit.Here's one place that carries the kit: http://www.boatfix.com/bykeywordnew2...&submit=Search This is a kit with impeller, pump plate and gaskets, etc. For a complete pump kit with upper pump housing and lower pump body, it's 18-3314. The Mercury part number for the complete kit, would be 46-96148A8 ($40.85 U.S. at the Merc dlr).G'Luck........ed
  #6
Old October 13th, 2005, 10:27 AM
thanks for you help ...gracias y muchos saludos desde tijuana mexico..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 9.9 starting problem bsailn1 Mercury & Mariner Outboards 0 April 26th, 2006 06:00 PM
mariner starting problem gungho johnny Mercury & Mariner Outboards 8 April 10th, 2006 06:37 PM
PROBLEM STARTING MOTOR 115 MARINER jornelas Non-Repair Outboard Discussions 1 October 11th, 2005 04:03 PM
mariner 9.9 starting problem theis Mercury & Mariner Outboards 1 March 10th, 2005 05:15 AM
mariner 25 starting problem ews109 Mercury & Mariner Outboards 1 May 16th, 2004 12:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
