  #1
Old October 10th, 2005, 03:14 PM
TheChad TheChad is offline
Default 1979 Mercury 40HP - Disconnecting Linkage, to remove motor...
Hi,I need to disconnect the linkage on my 1979 Mercury 40HP, so i can remove the motor from the boat, so i can fix the transom.How do i go about disconnecting the linkage, and please give me any tips that will aid in the removal and or reconnection of any of the linkage..Thanks for the help!-TheChad
  #2
Old October 10th, 2005, 05:49 PM
Silvertip Silvertip is offline
Default Re: 1979 Mercury 40HP - Disconnecting Linkage, to remove motor...
1) disconnect the positive and negative battery cables and clip any wire ties that would prevent removal of the cables when the engine is removed. 2) Disconnect the fuel line at the engine. 3) Disconnect the engine electrical harness at the engine. 4)The throttle and gearshift cables attach to the linkage at the engine. Disconnect the end of each cable where it attaches to the linkage. Then remove the cable itself from its anchor. 5) With some sort of lifting device in place (block & tackle, engine hoist, etc., remove the four mounting bolts and lift the engine off the transom. If you need more detail than that, you also need a service manual specific to your engine. If the cables were adjusted properly prior to engine removal, they should be ok when its reinstalled. PROVIDED -- nobody has turned the threaded anchors on the cables.
  #3
Old October 17th, 2005, 01:55 PM
What is the proper way to disconnect the steering from the engine?Also Incase anyone reading knows... Is there a way to adjust the steering when I reinstall it? My engine turn's plenty 1 direction, and hardly at all in the other..Thanks!-TheChad
  #4
Old October 17th, 2005, 06:32 PM
Remove the nut that secures the steering link to the end of the steering cable. Loosen the large nut at the opposite side of the tilt tube and pull the cable out of the tilt tube.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
disconnecting shifting linkage from lower unit brick551 Johnson & Evinrude Outboards 9 November 2nd, 2005 05:24 AM
1979 Mercury 40HP - Trouble running at idle... TheChad Mercury & Mariner Outboards 7 October 4th, 2005 08:22 AM
1979 40hp linkage issues.... Captain12pk Mercury & Mariner Outboards 3 July 8th, 2004 07:58 AM
disconnecting shift linkage? brentwhitis Mercury & Mariner Outboards 3 April 17th, 2004 01:09 PM
1979 40hp Mercury won't turn off KeithS Mercury & Mariner Outboards 3 July 24th, 2002 03:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
