Usually a spun prop can still spin if spun by hand. A real test would be mark a spot on the hub and the prop, give it good throttle, and then make sure the lines are still lined up.
But since you said you don't feel/hear the clunk when shifting into gear, it sounds like your shift shaft is not aligned in the lower unit. I never heard of this happening suddenly as in your case. To check, just undo the 6 bolts holding the lower unit on (don't forget the bolt underneth the trim tab), and keep sliding the lower unit downward until you can see the shift shaft. You don't need to fully drop the lower unit to do this. The shift shaft is on the side closest to the transom of your boat.
If confused send another post
