1994 Skeeter zx175
Bottom Rig
Would you guys consider a 1994 Skeeter ZX 175 that the seller is asking $7900.00 that had this much repair done to it? Would you want a marine survey before considering this boat? What would you offer the seller?<br />Boat INCLUDES the Following:<br />Two Year old 65lb 24v MinnKota AT Foot Control Trolling Motor <br />Hot Foot <br />Wheel Trim <br />Mercury 175 EFI, Compression 112 -116 <br />Owner Replaced Trailer Tires Recently <br />New Winch Strap <br />New Auto Bilge Pump <br />New Dual Pro 2-Bank Battery Charger <br />Recently Replaced Steering Cables <br />New Power Trim Motor On Engine <br />Added Livewell Pump-Out to One Livewell <br />Only Used Mercury Premium Plus Oil <br />New Water Pump <br />New Spark Plugs <br />Lower Unit Oil Changed and Serviced Annually <br />Batteries, SS Prop, Etc… ALL INCLUDED
Ron G
Re: 1994 Skeeter zx175
Sounds like a fair deal,take it out and test it.
skeeterboy
Yea i would take it out and test it out and see how she rides along with how everything works.
gonefishie
<br /><br /> Mercury 175 EFI, Compression 112 -116 <br /><br />
Wow, a 175 on a 17 footer? that would be a rare find but I would be worry about the compression. A good number would be in the 130 range. I'll offer $5k and during the test run if top speed is not at least 60+mph at 5200-5500rpm, I'll tell that guy to keep his boat.
