  #1
Old September 22nd, 2005, 07:32 PM
pine island fred pine island fred is offline
Master Chief Petty Officer
Default removing power head 4 cyl mariner
Finally got a chance to take the motor out for a run today. It is a 92 or 93 40 horse 4 cyl mariner. Ran smoothe at all power settings. One problem came up that I did not find with it on muffs. Big time exhaust/ water leak between the power head and leg. Bought a SELOC manual, which i guess is a good book, but it covers every damn 2 stroke mercury made. Have to pull the power head and cant figure out how many bolts hold it on. Found 4 studs aft 2 on each side with nuts that came off surprisingly easy. Looks like there is a long thru bolt forward that has to come out. That makes 6. Do not want to miss something and think the head is seized to the shaft. Looking for guidance on the total nbr. of studs and bolts.
  #2
Old September 22nd, 2005, 08:18 PM
north40 north40 is offline
Default Re: removing power head 4 cyl mariner
6 is correct.
  #3
Old September 23rd, 2005, 02:58 PM
Moody Blue Moody Blue is offline
Had mine off this spring. Remove the lower cowling to reveal the fasteners. Can't remember for certain but I thought there were 8. Four on each side. The two front nuts could not be completely removed until the powerhead was raised slightly because of the stud length.
  #4
Old September 23rd, 2005, 06:12 PM
Yep, it has 8. Power head is seized to the shaft. Big fix there according to the book is drill a hole in the leg and cut it with a torch. Fix in my book is I put it back together and will run it with the exhaust leak. Runs to good to just forget it but not worth getting any deeper. regards fred
  #5
Old September 23rd, 2005, 06:25 PM
joblo33 joblo33 is offline
You sure the leak isn't in the exhaust plate? (port side). That's where they usually spring a leak. You can probably change the exhaust gaskets without pulling the powerhead.Eric
  #6
Old September 24th, 2005, 05:28 AM
No, wish it were. Exhaust and water mist spray from under the cowl into the boat. Removed the exhaust plate on an older 50 yamaha a few years back during a rebuild, wont do that again. Snapped 12 of the 14 bolts that held the cover on. Age and saltwater isn,t kind to engines around here. People here scoop up on fresh water motors brought down by the snowbireds regards fred
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
removing power head from 71, 9.5hp Johnson gmarshall43 Johnson & Evinrude Outboards 2 March 1st, 2007 08:17 PM
Mariner power head replacement?? Ghost Rider 2 Mercury & Mariner Outboards 1 February 28th, 2007 09:29 AM
removing power head from 35hp Johnson jdupree Johnson & Evinrude Outboards 8 October 14th, 2006 03:41 AM
Removing power head mjestey2000 Johnson & Evinrude Outboards 6 February 24th, 2003 05:00 AM
removing power head on 15 hp big joe Johnson & Evinrude Outboards 5 June 6th, 2002 10:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
