problem with load
nsl
hi, my 1979 mercury 40 hp outboard is running fine in neutral and when out of water in forward, but when it´s lovered in the water and it feels the "weight" of the boat it is only able to run at low revolutions. does enyone know where to start? <br />Thank you, nsl
Vlad D Impeller
Re: problem with load
By running out of water, i assume you mean with on muffs?<br /><br />see decarb in the FAQ section of the forum.
Silvertip
The motor will idle slower in the water since it now must deal with exhaust back pressure.
