I recently purchased my boat and noticed that when manually spinning my prop, it has a wobble to it. It had actually broken off a bit of the bearing carrier but I think that is fine. I pulled the prop off and, using the depth end of a digital caliper, checked the prop shaft from the LU housing. I had almost no movement at the shaft. I will get my hands on a dial indicator to verify but has anyone heard of a prop spinning out of round like that (damaged/defective prop hub)? 2001 Merc 75 with a 3 blade 13x21 stainless prop. Thanks.
