Chelquay, The Stator and trigger are 2 different animals.
The stator supply the current, (alternator).
The Trigger creates the pulses for the firing of the coils. The trigger is like an electronic distributor.
I removed mine using a harmonic balancer puller for a car.
I used the 3 bolts of the puller in 3 of the flywheel plate cover bolt holes. Be careful not to screw them in too far, as these holes are bottomless. If you go too far you will damage the trigger pick up magnet that is bolted underneath
