  #1
Old August 29th, 2005, 02:45 PM
Gone Gone is offline
Default 25 HP Mariner Hard Starter
Has new carb. It will only start if you push the enrichment pump once with about 1/3 throttle. It'll fire up but won't run down to an idle.There seems to be no suction through the carb during cranking. Compression is good! Reeds look OK and no backpressure through the carb....no vacuum either as I said.Is there a common problem within the cases? Crank seals?
  #2
Old August 31st, 2005, 05:57 AM
Default Re: 25 HP Mariner Hard Starter
Bump
  #3
Old August 31st, 2005, 06:13 AM
Laddies Laddies is offline
There has to be vacume at the carb or it would not start at all, make sure you have spark on both cyl. then make sure the carb is clean and after reinstalling it do a syn and link on it making sure you have the right specs as there are several differant carbs and spec, use the wrong ones and the 25s can be bears to start--Bob
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #4
Old August 31st, 2005, 08:07 AM
Zactly my thoughts. If I keep tickling the enricher, it will keep running at a very fast idle as long as the gas holds out.There is no vacuum even without the carb which leads me to believe that the two cylinder crankcases are leaking to each other and cancelling out the vacuum. Second handedly, I have been told that this is common in this model, perhaps even a casting problem. I need some verification before I tear into it vs replace it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
hard starter Drowned Rat Johnson & Evinrude Outboards 4 May 6th, 2005 02:01 PM
hard starter Drowned Rat Non-Repair Outboard Discussions 2 May 6th, 2005 11:23 AM
'80 50hp Merc starter slow / hard starting Dee Rambin Mercury & Mariner Outboards 1 May 3rd, 2005 02:50 PM
95 mariner 150 outboard hard miss at low RPM beaverlake66 Mercury & Mariner Outboards 3 June 15th, 2004 04:58 PM
25 hp Mariner hard to start spekltrout2002 Mercury & Mariner Outboards 3 September 1st, 2002 03:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
