KennebecRiverGuide
Thread starter- Joined
- Oct 25, 2004
- 16
I am looking for a source for a rebuilt (or new) driveshaft with bearing and seal assembly for a 1998 Mercury Sport Jet 80 Outboard (115 Hp 4 cylinder powerhead).<br /><br />The pump is an Outboard Jet model "AC", Serial Number 63.100..<br /><br />My current bearing assembly seems to be fairly tight but I am starting to get some discoloration in the grease (turning greyish) indicative of water penetrating the seals.<br /><br />I don't want to take my engine down for some unknown period of time while I send the shaft out to be rebuit by a shop (bearing must be torched off), so would like to get my hands on a prebuilt shaft/bearing assembly to install myself. Would consider buying a whole pump assembly with shaft if in good condition (also looking for a nylon sleeve, Shear key, thrust cone insert and shoe/grate as spares).<br /><br />Clam's can you rebuild this shaft for me? I live outside of Augusta.<br /><br />Thanks in advance for any suggestions.
