"I know that there MIGHT be water pump, fuel pump, coil, carb and/or other problems after long storage, but is there any reason why I shouldn't hope for the best and give 'er a try before tearing anything apart??? "
_________________________________________________ _____________
After a 5 year lay-up, I would definitely replace the impeller and have the carbs cleaned, rebuild the fuel pump, replace the old gas with fresh gas and a new set of plugs before i even try to start her up.
