Re: Change lower unit oil.
Should be indented into the unit next to the vent plug (vent). If you have 2 at the top, one a bit larger and the other smaller, the smallest is the vent plug and the largest is the waterpump "flush" plug. Take out the drain plug at the bottom, and remove the vent plug. Buy a gear oil pump kit at wal mart (about $7.00) and it screws onto the quart bottle of gear oil and also threads into the drain plug hole. Fill by pumping till the oil comes out the vent plug hole, this removes all air from the gear case.
