  #1
Old August 22nd, 2005, 07:56 AM
Flash214 Flash214 is offline
Default Fuel Mixture Screw? for 1985 Mercury 60
I just bought a 1985 Mercury 60 ( 3 cyclinder) from a guy and put it on my pontoon boat. The motor runs great but seems to be a little rich on the low end. I work on two stroke motorcycles but haven't done a lot on boat motors. On a 2 stroke motorcycle the mixture screw is usually called an air screw. Turn it out (counter clock-wise) and it adds more air thus leaning the mixture. And vise-versa...turn it in and richen the mixture by not allowing as much air in.Does the mixture screw on this boat motor work in the same way? Someone told me it was the opposite, meaning that the mixture screw is a fuel screw and that turning it out would actually richen the mixture by allowing more fuel in.Can someone clear this up for me as I have not ordered a manual yet.By the way, the settings are now set at 2 3/4 turns out for the top carb. and 3 1/4 out for the bottom. That is the way it was when I got it.
  #2
Old August 22nd, 2005, 08:43 AM
fishingdan fishingdan is offline
Default Re: Fuel Mixture Screw? for 1985 Mercury 60
The idle mixture screws adjust the fuel. So I guess they can be called fuel screws. In=leaner, Out = richer.
  #3
Old August 22nd, 2005, 09:48 AM
Thanks, that is what I was hoping since it would explain the richness of the mixture. The screws seem to be backed way out at the current settings making it run rich on the low end.Is there a general area to start from with these carbs.? I usually use 1 1/4 to 1 1/2 turns out as a starting point but again this is on motorcycles where the mixture screw is an air screw.thanks for the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Yamaha 9.9: Where is the Idle Fuel Mixture screw? (pic) ST Yamaha & Suzuki Outboards 5 April 16th, 2006 03:02 PM
Fuel mixture 1985 Evinrude 6 hp bobpanian Non-Repair Outboard Discussions 2 July 16th, 2005 02:19 PM
mixture screw setting 1985 6 hp grizzlyadams73b Johnson & Evinrude Outboards 1 June 13th, 2005 09:32 PM
Air/Fuel mixture screw... suzuki40 Johnson & Evinrude Outboards 2 July 25th, 2003 11:04 AM
carb air fuel mixture screw guru Force & Chrysler Outboards 1 April 5th, 2003 02:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
