Re: Alternator?
Does your question mean that your battery isn't charging? That's possible. There should be two regulators sandwiched between the exhaust cover and coil mounting plate. If you ever connected the battery backwards, even for a second, they're dead. Loose and/or corroded battery leads can also cause failures. If you have a tachometer and it's not working, that's a frequent indicator of a failed regulator.
