Re: Merc 115 Straight 6
If it dies at 2/3 throttle, the it probably isn't the "IDLE" mixture screws.<br /><br />Have you set the "snych and link" by the manual yet? That's a good place to start. Then, you may have a fuel delivery problem. <br /><br />Try this: As it starts to lose power, push the choke. Does it pick-up and run? <br />Try hooking a 6 gallon portable tank to it. Does it still have the problem? If no, then you have a fuel delivery problem with the tank/pickup/fuel lines/bulb, or somewhere in the boat.<br /><br />If it still has the problem, disassemble the fuel pump, look at the diaphrams/gaskets there, as well as the check valves. (Important) do not re-use them even if they look good.<br /><br />Let us know how you make out...
