Re: hard starting 115hp mercury
The trigger is in the distributor, it's part of the ignition system.I'm no mec. by no means though,so i'm not sure if yours has one, or if that would be the problem.What mine would do was some times it would give fire to only some of the spark plugs, or none of them, and then all of them.I would be on the lake running fine for a while and then it would just stop and wouldn't start.My mec. said that triggers will sometimes fail slowly over time, not always just go out at once.They are expensive and i'm not sure if a person could check them other then checking spark.I have also heard that switchboxes will do the same, sometimes work sometimes not.I am not sure if yours would have one or not also.My experience is with a 1974 115 six cylinder.I know Clams would know he seems to be the expert on these.
