  #1
Old November 16th, 2005, 06:04 PM
dsiedt dsiedt is offline
Default Best way to tow skier behind Center console w/outboard?
I have a SeaPro 180cc and I would like to pull some water toys instead of fishing on some days next season...I have rear cleats with 1/4 or 1/2 plates on the under side and also have "u shaped" bolts on the transom near the sides.Should I use the cleats, or u shaped fasteners to tie the v-shaped bridal?
  #2
Old November 17th, 2005, 02:49 AM
ziggy's Avatar
ziggy ziggy is offline
Default Re: Best way to tow skier behind Center console w/outboard?
i've always used the u-shpaed bolts on the transom to tow with. i've always used the cleats to tie up to the dock with. ya didn't say, but i would assume that the u-shaped bolts have back plates too. guess ya could look to make sure.
__________________
'Lime Time'
1975 AristoCraft Nineteen
Mercruiser 165hp (chevy 250 L6), 1 drive
  #3
Old November 17th, 2005, 03:36 AM
swist swist is offline
The U-bolts on most boats are through-bolted through the transom with backing plates- the thickest part of the hull. If these fail, your boat is about to fall apart anyway :-)Installation of cleats is highly variable from brand to brand, but if yours are solid, they are a lot more convenient and accessible to work with for tow ropes.
  #4
Old November 17th, 2005, 08:07 AM
JasonJ's Avatar
JasonJ JasonJ is offline
I use the transom eyes, and I have one of those cable things with quick connects on each end. The quick connects go on each tow eye. There is a widget on a roller with an eye on it. The tow rope is tied off on the eye, and the roller allows the widget to move along the cable. Makes turning and whatnot a little better for those who are being towed, and it keeps everything out away from the outboard. I have towed several boats with my transom eyes so I know they are up to the task. You really don't want to use your cleats unless you can confirm that they are mounted very well. Most are just screwed into a wood backing. A large water toy would loosen then rip those out in no time. Good luck...
__________________
Project Skanky Beast http://70silverline.250free.com/Skankybeast.html
  #5
Old November 17th, 2005, 09:00 AM
AguaSki's Avatar
AguaSki AguaSki is offline
Try clicking on this link. http://www.westmarine.com/webapp/wcs...001/391/390/23 I am not sure if I properly posted the link so you may need to paste into your browser.I think this is similar to what JasonJ is describing. I use this all the time when skiing or pulling tubes. The two hooks attach to the transom eyes.
  #6
Old November 18th, 2005, 07:54 AM
Thanks! My boat has 1/2" stainless plates under the cleats, but I will use the transom u bolts and purchase the quick connect rope.
  #7
Old November 18th, 2005, 12:58 PM
ziggy's Avatar
even if they have steel plates behind them, they are not designed to tow with. do use the u-bolts on the transom....a quote from chapman piloting, seamanship & small boat handling book 63rd edition, pp. 31."While a good Quality, well-installed deck cleat is adequate for making fast in a dock, it is not intended for towing-which puts considerably more strain on hardware than making fast to shore."
__________________
'Lime Time'
  #8
Old November 20th, 2005, 06:05 PM
Thanks ziggystardust...My buddy confirmed what you stated. He explained that the steel plates under the cleats are strong and will prevent the cleat from pulling out up and down (y axis), but not a wise choice for side pulling (x axis) pulling. Any x axis stress should be limited to docking.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
20' center console rubberduck Wellcraft Boats 4 April 19th, 2007 05:35 PM
New Boat: Center Console , Walkaround, or Dual Console PAkev Boat Topics and Questions (not engine topics) 17 April 2nd, 2006 08:14 AM
Center Console - What is the best Ply? Knightgang Boat Restoration and Building 8 November 12th, 2003 06:18 PM
Center Console Scott-14 Boat Topics and Questions (not engine topics) 6 October 15th, 2003 03:18 PM
center console Billnicole Boat Topics and Questions (not engine topics) 9 August 7th, 2003 06:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
