Serial# 5264708 3 carb system. Had a mechanic rebuild my carbs.He replaced original low jets with updated ones but left original highs in.<br />Original low jets had little plastic balls that from my understanding would stop fuel flow at high speed, allowing fuel only through high jets. Should the high jets be sized smaller so that in combination with lows they equal the same fuel volume as the original high jets?
