Re: Prop swap - affect ???
Both props are 13 splines. There is plenty of clearance for the larger prop. No real objective, just curious about the result. Will it be better for pulling tubes etc or will I gain more top end etc with the larger prop. Are the two props "equivalent" as far as performance ? Will the larger prop bite better but turn at the same RPM because of the larger dia ? What is the better prop ? I mainly fish and pull tubes, water skiers etc.
