Re: Steering wheel won't turn? PLEASE HELP
I just finished working on my steering cable. Disconnect the cable from the motor and see if your motor turns side to side freely, if so carry on. Remove cable from back of steering wheel and see if wheel turns freely. Reason i say it this way is because I found my problem was the cable. Now if it is cable you will have to replace or see if you can get some kind of grease into cable. i first used WD40
