Re: Bearing Carrier Removal?
Put a couple of flat pieces of 3/8' metal beween the housing and an old prop or other spaces, install the prop retainer and nut, thighten the nut and it will pull the carrier, is some extreme cases you may have to heat the housing--Bob
