i have a 1994?mercury sport jet 3 cyl 90hp non oil injection,number oeo33796 with the bullit type connectors.fitted in my bayliner jazz,<br />the engine has lost all 3 cylinders ignition,did have spark on cylinders 2+3 but now have lost them all,<br />did swap coils,plugs and leads bettwen cylinders 1+2 but there was still no spark on cylinder 1<br />(2 still worked)but now has lost all spark on all 3.<br />engine has just been rebuilt and not fired since,did work prior to strip down.had new pistons,flywheel,plug leads,loom conectors where needed,battery,gaskets+seals etc.<br />it has a red stator (2 yellow wires/2green/white wires)with mars bar size box on switch box(recall mod?).the wiring diagram doe,s not show the box and the green/white stator wires(manual shows red and blue) and there is a red wire coming from switch box thet is blanked off (stator wire?)and blue stator wire to mars bar box.<br /> any body have a wiring diagram with the later red stator and extra box from it as i have seen that the testing is different on the original and red stators .or details of stator mods/rework the dealers did while they were under warranty.<br />have checked and cleaned all connectors,earths etc.
