I am attempting to install a brand new stator for my Mariner 200 HP, 1985. Is this job too big for a budding/novice boat repair mechanic???If so/If not any suggesstions on what to do and will I mess up the timing of the enging my removing the fly wheel.Cheers,W
http://www.biggerhammer.net/mercury/.../878079/2c.pdfSee the linkages sections in 2C. Don't mess with them or carb linkages and you'll be OK. The toughest part of the deal is removing the flywheel. An impact wrench (pneumatic or electric) helps here, then you don't need a FW holder to remove the nut and replace it. You will also need a FW puller, which is a special Merc tool.
How many bolt holes are in the top of your flywheel? Mine has 2 and I was able to make my own puller from an old lawnmower blade, a big nut, bolt and washer for the center, and 2 bolts that screw into the flywheel. You need to drill 2 holes in the blade for them. Screw the 2 small bolts into the flywheel, then use the large bolt to pop the thing off by tightening it through the nut and washer, which are placed on the underside of the center hole in the blade. WildOne is right...save yourself lots of grief by getting an impact wrench.
It sounds like a couple of people have never seen a 200 before, you will need to borrow or buy the correct puller that screws in the flywheel. Its available through NPPA or anyone who sells Sierra products
__________________
PLEASE, no service questions in PMs thats what the forums are for.
we have enough problems about without bogus puller info, buy and use the correct tool and its a 35 min operation. break off a bolt in the flywheel and ya just added 2 hours to it. buy the manual, buy the puller, DO NOT use an impact on the selflocking nut or it may trash itself and especially DO NOT use an impact to reinstall the nut, carefully clean the splines and taper with alcohol or similar solvent and properly torque the nut as per the service manual. a note of warning, me and most like me bill at 125 per hour to remove customer broken bolts .
