Did you breaak something? Probably not.
Was your test no good? You're done the pressure test, but not a vacuum test. The pressure test can show where the oil (not grease) could be getting out. A vacuum test is needed to see where the water is getting in.
The 'poof' you're getting is the shift shaft seal. It's only a water seal, not an oil seal, ie it will allow oil out but shouldn't let water in.
Was the oil milky when you changed it?
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
