tilt &trim acts erractic
ringo123
the tilt& trim on my 1992 mercury 115 will not read the correct position of the motor even after replacing sender switch with new kit"parts#821180a6 and had wiring check for correct hookup. the boat is 1992 ranger commanche.the guage reads in a erractic manner even though the motor works up and down perfectly.
DHPMARINE
Re: tilt &trim acts erractic
ringo123 Check the gauge positive and negative wires.If they aren't loose,you probably need a new gauge.<br /><br />DHP
