  #1
Old July 16th, 2005, 08:18 AM
kentrx1 kentrx1 is offline
Default mid-1990's mariner 3 cylinder 60 hp hard cold start
I have a 60 hp mariner (approx 1994 I think), 3 cylinder, that runs great once it is cranked. It seems to flood everytime I try to crank it. I am mixing the wal-mart brand oil with regular gasoline in the 50:1 ratio. I can shoot a dab of starting fluid in the intake and it will fire right up but sometimes will smoke quite a bit for the first few seconds. I have only had the boat for a month or so. It seems to run very smooth and idle well once I get it started and the engine "cleared" of the flooded conditon. Thanks for any and all suggestions!!
  #2
Old July 16th, 2005, 10:38 AM
Vlad D Impeller's Avatar
Vlad D Impeller Vlad D Impeller is offline
Default Re: mid-1990's mariner 3 cylinder 60 hp hard cold start
Welcome to iboats Do not squirt starting fluid into your carbs, if and when you do have to, try squirting some premixed gas instead. Are you fully priming the bulb and using the choke prior to starting?And what is the condition of the sparkplugs?
__________________
'The past is history, the future is a mystery,
and now is a gift. That's why it's called the present'
  #3
Old July 16th, 2005, 10:57 AM
YES, BULB TIGHT, USING CHOKE, CAN HEAR "CLICK". APPEARS TO BE FLOODING AND THE COMBUSITBLE STARTING FLUID....ONLY A SMALL AMOUT SPRAY AT THE OPENING OF THE BREATHER, GIVES IT THE SPARK TO GET GOING. USUALLY WILL DO OK FOR THE REST OF THE DAY, AND SOMETIMES EVEN THE NEXT DAY.
  #4
Old July 16th, 2005, 03:43 PM
hooksetter62 hooksetter62 is offline
are you using the choke properly? turn key on, push in on choke primer for about 5-7 seconds,release, lift fast idle lever on controls, then crank,dont hold choke in when cranking. give that a try. thats how my system works.hope this helps.make sure your bulb is pumped up hard. make sure vent is open on fuel tank.
  #5
Old July 17th, 2005, 05:58 PM
Thanks....I will give that a try. I was under the impression you were supposed to hold it pushed in while cranking and that has not been sucessful at all!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
hard start when cold brushhog Johnson & Evinrude Outboards 2 September 6th, 2006 01:06 AM
Hard start when cold cougar15 Johnson & Evinrude Outboards 10 June 2nd, 2006 10:51 AM
hard cold start rods Johnson & Evinrude Outboards 10 January 25th, 2006 11:55 AM
Mariner 150 - hard to cold start and stalls on low revs Gnirts Mercury & Mariner Outboards 9 August 13th, 2004 05:23 PM
120 hp Mercruiser 4 cylinder hard cold start JasonJ Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 July 15th, 2003 06:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
