  #1
Old July 15th, 2005, 07:04 PM
blako66 blako66 is offline
Default buying used boat
this is just for some information if anyone can help, i am thinkin about buyin a used sportcraft adventurer, from what i can tell it is either a 16 or 17 foot boat around a 1986. my question is it has a mercury 60 hp motor on it. we took it out the other day for a test run and to me it seemed to be dogish, no power, now the boat is rated at about 880lbs and i had about 700 lbs on it, it didnt seem to want to get on plane, there is no tachometer on it or speedo, should a 60 horse mercury push the weight i had on it and the boat weight, or should i invest in a 90 hp i want to be able to pull a tube and right now i dont think it can, thanks for the help
  #2
Old July 15th, 2005, 07:45 PM
mulliganmagic mulliganmagic is offline
Default Re: buying used boat
I have a 15 1/2 ft boat with a 70 on it, and with one person it'll do about 45 but when you put 4 people or so in it then it does bogg it down a little. It'll still move pretty good with that amount of weight though. However, you are talking about a bigger boat (more weight) plus an almost maxed out capicity and a smaller motor on top of that. Take it out by yourself or with two people in it and a light load and then see how it does. If it does ok then you might consider lightining the load a little, a bigger motor, or maybe looking for another boat in the same size range with enough power to suit your needs.
  #3
Old July 16th, 2005, 09:42 AM
wilde1j wilde1j is offline
What does the data plate say is max HP? 60 HP seems too low. I had a 14' w/ a 55 Hp and it was not overpowered at all.
__________________
Jim
  #4
Old July 17th, 2005, 04:22 PM
ok, more info for the boat i am thinkin about buyin, the placard on the side says it can take up to a 110 hp, it has like i said a 60hp mercury the problem i had when i test drove it was it wouldnt plane out with 4 people at about 700lbs, then when i put 2 up in bow it dove down but didnt increase speed, i just feel that something isnt right with the motor, i talked to a marine place and they said with the 60 hp it should pull a inner tube on the back, this one just dont seem to have any guts to it, i checked compression and i am at 120 on all 3 cylinders so that should be ok, who knows maybe santa will bring me a 90 hp motor, will that give me much more speed, thanks for the help Blake
  #5
Old July 17th, 2005, 09:18 PM
Laotzu Laotzu is offline
I was just out today with 6 people (50hp on a 16' aluminum fishing boat). It takes some time, but I could get on plane with two hefty's in the bow. When by myself it has no poroblem planing. about 25mph with just me and 20 with the crowd.What I have to do is to trim the motor all the way down to get up then raise it to gain the speed. It's a hassle with the crowd but I go mostly by myself or one of my grandkids fishing only.Jerry
  #6
Old July 17th, 2005, 10:10 PM
here is another problem i have, there is now tach or spedo on the boat, can anyone tell me what is a good price and where i can get a tach, it is a 3 cylinder motor, and how hard is it to hook up, the spedo should b easy i would think, also is there anywhere that sells them in a combo, hard to tell what a boat is doin without the tach, i would think that since compression is good that the motor is runnin good, but i cant tell by ear how many revs i am turnin to see if anything else is wrong, by the way the prop is a 13 pitch, if it dont seem like the revs are high by sound, would it hurt to goto an 12 or 11, i guess the most important thing to do is get a tach hooked up first, do they still make them for 3 cylinders, or do i need to get a used one, thanks again for all the help, i dont know if i have mentioned it before but boat ways about 1250 and i would be loadin it with about 600 lbs, i just hope this 60hp will do the trick, although i can get a used 90 johnson for about 3200, that is more than i am buyin the boat for, again thanks for all of your guys helpBlake
  #7
Old July 18th, 2005, 05:56 AM
Motor Boater Bill Motor Boater Bill is offline
You need to use a tach to diagnose this, I think. If you are not reaching the WOT rpm's spec'ed for the motor, you need to correct that. This could be a problem with the motor such as needing a fuel pump or carb rebuild or it could be a mismatch of the motor/prop/boat. If the motor is marginal in terms of power for your boat, you might even need to used different props according to what you are doing (pulling a tube) or the load in the boat. But for starters you need to be able to measure your rpm's.
  #8
Old July 18th, 2005, 07:20 AM
where can i get a tach for 3 cylinders, is it a special tach or is there a universal tach that works for all motors, thanks againblake
  #9
Old July 18th, 2005, 09:38 AM
north40 north40 is offline
You need 75 to 80 percent of what your boat is rated for. I would say a 90 hp would be minimum or you probably won't be happy.
  #10
Old July 18th, 2005, 10:02 AM
BF BF is offline
ditto... I think a 60 hp on a boat rated for 110 is likely gonna be a dog no matter what. Sure, if someone gave it to you, you'd make it work for awhile. But, if it were me, I'd hold off and wait for a boat I like that is more appropriately rigged.... that's usually cheaper than repowering. If you've already taken the plunge, then yes, you can get a tach and make sure you're propped right.... one problem with an underpowered rig is that it makes the propping and weight load of the boat crucial since the motor doesn't have a lot of surplus torque/hp.good luck
  #11
Old July 18th, 2005, 10:35 AM
well i am on my way, just picked up a tach for 25.00 he couldnt find it on his inventory so he sold it to me that cheap, it has a setting on the back for a 3 cylinder so it should work, now i just need to get it installed and takin to a boat shop. they said they will run test on the electical system includin stator. i will have them install the tack it will b a few weeks i will keep all posted, also the man i have workin on it told me he can put a used 87 johnson 90hp, and if my motor is good he would take mine on trade, so if the 60hp isnt good enough for my needs, the door is open on a 90hp thanks again to all that have helped, i will keep everyone posted on what happens and what i do,Blake
  #12
Old July 18th, 2005, 10:37 AM
oh one more thing i forgot to ask, if i do decide to go with the 90 hp johnson, how do i measure the shaft to make sure it isnt to long or short for my boat thanks againblake
  #13
Old July 18th, 2005, 11:45 AM
jasonbailey jasonbailey is online now
Measure the transom.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
buying a boat fnulnu Boat Topics and Questions (not engine topics) 2 March 5th, 2006 11:55 AM
Need help buying boat..PLEASE snagnever Boat Topics and Questions (not engine topics) 8 April 14th, 2005 04:15 PM
what to look for when buying a used boat amitropo Boat Topics and Questions (not engine topics) 3 January 22nd, 2004 01:20 PM
Buying a new Boat Shermanator Boat Topics and Questions (not engine topics) 2 June 26th, 2003 03:03 PM
Need more help on buying 1st boat please rocks beware Johnson & Evinrude Outboards 3 July 31st, 2001 08:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
