fatpratt1996
- Sep 19, 2004
- 221
Hey guys, I just wanted you all to know that after all of my seemingly dumb questions and a good decarb my '99125 Elpto is doing great. I had wierd little problems every now and then but (knock on wood) It is running as good as this motor can. I also tweaked my prop(took one of those little rubber inserts out) and my hole shot improved a lot too. I started with all three inserts but it wouldn't plane at all, put one back in,same, pu one more in and off I went. It takes all of 2 seconds from a dead stop to get fully out of the hole. What sucks is I am probably due for the imp. change but she is running so good and the pee hole is squirting strong as ever. Anyways thanks guys for explaining a lot about this engine to me. You were a great help.
