  #1
Old July 1st, 2005, 04:40 AM
timo14 timo14 is offline
Default 1986 Mercury 150 Black Max Carb Leak
1986 Mercury 150 Black Max. Fuel is leaking out of the front of my carbs (all 3 of them) when the motor is tilted up. I did not notice it until I installed a new fuel filter (external with water separator) and primer bulb. When I pumped the ball it had a lot of air in it, so i pumped it alot. I first thought i flooded the engine. But it started right up. It runs great otherwise. I have read in other posts that i shoud keep some rags handy & not worry about the leak. Seems a little fishy though.Thanks in advance for any help.
  #2
Old July 1st, 2005, 06:48 AM
dingbat's Avatar
dingbat dingbat is offline
Default Re: 1986 Mercury 150 Black Max Carb Leak
I rebuilt all 6 carbs and mine still does it. It's the nature of the beast I guess.
__________________
Grady White Seafarer
200 Evinrude Ocean Pro
  #3
Old July 1st, 2005, 07:23 AM
heybaylor heybaylor is offline
if you tilt it all the way up ..yep it spills the gas out of the bowl vent ..something about gravity..But , mercury has installed a "suckit " valve in the lower corner of the silencer ( airbox) when it spills into the box , the next time you start it, it pull's the mess into the intake manifold ...Tip" keep your airbox wiped out every once in a while to get rid of the dirt/dust that settles in there ...dirt will be sucked in , and worst case , clog the valve ..and the mess runs out ..especially if your gasket ( airbox) is missing and or bad seal.my 86 XR2 stays pretty clean ..with a little maintenance.. and I seldom have a reason to tilt it all the way up ..about 45 degrees is plenty ..hope this helps ..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Mercury Black Max XR4 Won't fire conner172 Mercury & Mariner Outboards 5 October 9th, 2006 11:32 AM
1986 200 HP Mercury Black Max Wiring Woes Sundance13 Mercury & Mariner Outboards 2 June 14th, 2006 10:28 AM
Carb. Leak on Mercury 25 hp Blacky Non-Repair Outboard Discussions 1 April 30th, 2006 06:34 PM
Carb. Leak on Mercury 25 hp Blacky Mercury & Mariner Outboards 1 April 30th, 2006 06:34 PM
carb leak mercury black max 200 dcfrank3 Mercury & Mariner Outboards 4 May 5th, 2005 08:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
