  #1
Old June 29th, 2005, 08:18 AM
shelbik shelbik is offline
Default Mariner not getting rmp's in gear
When in neutral my rpm's are fine, once boat is in gear I am not getting enough rpm's and will only run about 30 mph.Motor is either an 85 or 86 200HP outboard Marinerany ideas would be a great help!Tk
  #2
Old June 30th, 2005, 06:44 AM
Moody Blue Moody Blue is offline
Default Re: Mariner not getting rmp's in gear
Not enough info shelbi. Can you provide more details ? Boat, prop, symptoms etc. 30mph would be good if it was pushing a 26ft 12000Ib boat.
  #3
Old June 30th, 2005, 07:08 AM
18ft Skeeter bass boat, 3 blade prop Getting 2000 rpm's when in gear and in water. When in neutral I am getting all the rpm's I need.
  #4
Old June 30th, 2005, 10:07 AM
wilde1j wilde1j is offline
Revving engine in neutral tells you nothing, other than the engine will run. Under a load is what counts. How do you get 30 mph at 2000 RPM? Most boats need over 3K RPM to plane. What RPM did you used to get?Carb or EFI?Have you checked the fuel system from the tank to the fuel pump for leaks and/or obstructions? Have you checked the fuel pump?
__________________
Jim
  #5
Old July 1st, 2005, 05:32 AM
Shelbi revving your motor above 1500-2000 rpm without a load (neutral) runs a good risk of it tossing parts through the block. I also am wondering how you achieve 30mph at only 2000rpm. What prop are you running ?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner gear shift rahn112 Mercury & Mariner Outboards 1 August 10th, 2006 03:32 PM
Mariner 15 gear selector help Fishbreath47 Mercury & Mariner Outboards 0 October 26th, 2003 07:08 AM
Mariner 15 gear selector Fishbreath47 Mercury & Mariner Outboards 2 October 11th, 2003 07:29 AM
mariner gear box bob williams Mercury & Mariner Outboards 1 August 6th, 2001 01:03 PM
5 hp mariner won't go in gear zon Mercury & Mariner Outboards 2 May 28th, 2001 05:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
