  #1
Old June 28th, 2005, 12:58 PM
nogimmies nogimmies is offline
Default 2000 Mercury Bigfoot 50 HP 4 stroke-Low oil pressure
This thing is still driving me nuts---------------- 0T008360 ser #I'm getting low oil pressure at idle and 1500-2000rpm.At idle my tee'd in pressure gauge shows ZeroAt full throttle 30-35 lbsI removed the pump and inspected it.It is on the bottom of the camshaft. Had to pull the head. It looks fine No scoring,scratches dings etc. The pumps tolerance specs measured within or better than the manual.I'm wondering if there is something on the suction tube that could be defective or if there is some other o-ring between the powerhead and the adapter plate that could be giving me fits. When this motor warms up, as soon as you engage the throttle/ gearbox the alarm sounds.I've also noticed that by pulling off the sensor lead to the sending unit the alarm still sounds until reset by shuting the engine off. upon restarting the alarm ceases with the wire off the oil pressure sensor. Which is normal.This low pressure at idle has me stumpedMerc says(Factory) that at idle this thing should have 3-5 lbs to satisfy the sensor.Any clues from you Merc Guru's??????
  #2
Old June 28th, 2005, 01:06 PM
Default Re: 2000 Mercury Bigfoot 50 HP 4 stroke-Low oil pressure
I forgot to mention that Merc recommended going from 10-30 wt oil to 25-45.I went One better and added2.5 qts 20-50 plus 1 pt of STP oil treatment the honey thick stuff figuring that if the pump pressure would increase.It did not.But i'm getting good lubrication. After running the engine I pulled off the valve cover and everything is coated well.Still am looking for some answers or ideasMercury Marine Hdqtrs in Fond du Lac ,Wisc. so far is useless in helping with this problem.This will be the last Merc I'll Buy.I'll go to Yamaha or Susuki next time.
  #3
Old June 28th, 2005, 02:33 PM
HSEMJ HSEMJ is offline
well it could be you oil pickup screen in the sump is partly pluged, or it's more likely the oil pressure relief valve is sticking open IMO. Which is located in the sump mounted on the bottom of the exhaust adaptor plate.ps: that engine block and head is yamaha made
  #4
Old June 29th, 2005, 07:58 AM
I found the problem and it was the pressure relief.Pulled the powerhead and found relief sticking open.Made repairs and now I get 40 lbs of oil pressure at idle.YaaaaahhhhhhhhooooooThanks for the advice!!!!!!!!!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury Bigfoot four stroke 25hp alienator Mercury & Mariner Outboards 0 August 10th, 2006 03:29 PM
2000 Mercury Bigfoot $ stroke-Audible Alarm nogimmies Mercury & Mariner Outboards 2 June 19th, 2005 08:16 AM
2000 Merc 40 Bigfoot 4 stroke idle probs MNboater Mercury & Mariner Outboards 0 May 23rd, 2005 08:25 AM
Max RPM 9.9 4 stroke Mercury Bigfoot Sailpower jlyar Mercury & Mariner Outboards 0 June 2nd, 2003 01:14 PM
Mercury 40 Four Stroke BigFoot Noise haggertb Mercury & Mariner Outboards 5 June 14th, 2002 01:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
